Old 10-Sep-2011, 7:49 PM   #2
Tower Guy
Originally Posted by Markm View Post
The antenna will be mounted outside on top of a cyclone platform around 40' with a clear shot of Chicago, Il. The run of RG6 could be as far as 100-150 feet.
The loss of 150' of RG-6 will approach 10 db. WWTO on VHF channel 10 is extremely strong, so preamp selection will be critical.
One approach is a UHF only aimed at 210 degrees with an AP4700 UHF only preamp.
If you tried for Chicago only you'd likely miss CBS. A rotator in a break room will be too confusing.
