Like I said, I will not be mounting it on the roof. Not gonna attempt to do that by myself and can't afford to have someone else do it. Just like I can't afford to just go out and buy all new antennas to replace what is mostly working at the moment.
Still working on trying to figure out how to better aim the uhf antenna. It's just a matter of figuring out how to mount it so that it's at the proper angle.
I'm assuming that aiming it to 304 degrees is to try and pick up Fox better, but I am thinking that will make CW worse?
Also, the amps suggested, those are to overcome signal loss from splitting the signal and long cable runs, correct?
