Old 10-Sep-2011, 4:44 AM   #18
No static at all
No static at all's Avatar
Getting the antenna outside at least 5 feet above the roof line should improve reliability. An eave or chimney mount would be easiest, but not sure which would work best for you. A tripod is another option, but I personally don't like drilling holes in the roof.
You may not need the preamp with the antenna outside, so I would try without it first.
