Old 10-Sep-2011, 12:21 AM   #2
John Candle
Tv Antennas and Reception
I recommend a Antennas Direct C5 antenna with the reflector screen removed , this makes the C5 into a 2 direction antenna. Aim the front receptor that has the coax connection at about 336 degree magnetic compass , the antenna will receive VHF high channels 7 thru 13 stations to the north west and south east. I also recommend a Antenna Craft U4000 antenna aimed at about 304 degree magnetic compass. Turn the metal reflector bars of the U4000 from the horizontal position to the vertical up and down position , this gets the reflector bars out of the way so more signal can be received through the back of the U4000. I also recommend a Channel Master CM3412 two way distribution amplifier or CM3414 four way distribution amplifier. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. The C5 comes with a UVSJ , so that will give you a extra UVSJ to use some where else.
