Andy is right on the money with his recommendations, but I must reiterate his caution about using an omnidirectional antenna indoors: most people are NOT successful using an omnidiretional antenna in an attic because of those antennas inability to reject multipath interference, and attics are hotbeds of multipath.. If you go with a Winegard HD-7694P or a AntennaCraft HBU-33 aimed at 180 degrees by your compass, all the Richmond stations will come in well, which are most likely the stations in which you are interested.
