Old 9-Sep-2011, 10:47 PM   #1
Vorkosigan
Improving Reception
http://www.tvfool.com/?option=com_wr...8387662941ff91
I'm in the process of trying to ditch Directv. I found an antenna already in my attic and am using that for the vhf and a homemade antenna for the uhf and have the signals combined with a uvsj. The vhf antenna points approximately NNW and the uhf antenna faces that direction as well.
Currently it's a straight shot with a couple of barrel connectors to the wall plate that feeds a HTPC. The total run is around 100 ft of quad shield RG6. I plan to add 1 or 2 more tv's, at least, in the near future.
This is actually working out great for the most part. The only issues I seem to have is that Fox, the CW, and Ion like to cut out randomly for a few seconds. I probably won't be watching Ion too much so I don't know how often it does it on that channel. Fox will do it maybe every 5 minutes or maybe every hour, but CW is much worse and will do it every couple of minutes for a much longer period of time. Both of those channels are important.
What are my options to improve my reception on those two channels? Keep in mind, I will not be mounting an antenna on the roof at this time. If I've left out any other details that are needed, let me know.
Thanks in advance.
Vorkosigan is offline   Reply With Quote
