Tv Antennas and Reception
A bigger antenna is now needed. After the August 31 2011 , target date , digital transition date , tvfool is showing in the pending applications for digital channels , 3 receivable digital channels to the south west. Pending applications included is also showing receivable Analog Tv stations to the south west and other directions. The digital stations are of weak signal strength , some of the analog stations are stronger signal strength. A antenna and antenna rotor works ok with one tv , however if more the one tv is connected then disagreements will arise over the direction the antenna is pointed. Additional antennas and wiring can be done to supply signal to more then one tv so that every one can receive what they like. So in order to know what antenna situation installation is the best , we needed to know --> how many tv's are/will be connected.
