Thread: Antenna Help!
Old 9-Sep-2011, 12:59 AM   #13
You know something about Tv reception , I like that. There is the RG-6 coax , you can get that local. The coax that has the newer compression type fittings , not the the older crimp type , is the best to use. The compression type fittings do a much better job of sealing out the weather and are made of higher quality metal and plastic.
