Thread: Antennae Help
Old 8-Sep-2011, 9:04 PM   #5
hankhepler
Re: Antennae Help
Try in the attic if the roof is not metallic. Locate the antenna so that it does not face duct work or other metallic obstructions.
If you get acceptable reception, the antenna will last indefinitely. It can be moved outside if needed.
Will do..ordering the DB2 and 50ft of 75Ohm RG-6 cable and I should be set. Will report back findings...
Thanks so much!
Hank
hankhepler is offline   Reply With Quote
