Thread: Antennae Help
Old 8-Sep-2011, 8:53 PM   #3
hankhepler
Re: Antennae help
A small Antennas Direct DB-2 facing about 65° would receive all the channels in the green section of your report. After disconnecting the cable drop from the grounding block you can connect your antenna to that point, feeding all the outlets in the house. You're right, you have plenty of signal so resist any temptation to use any type of amplifier.
Thank you! In attic or on the side of the house? Mounted on the side of the house would be worried about wind and storms...have a standard type shingles (architectural I believe)...
Thanks again for your help!
Hank
hankhepler is offline   Reply With Quote
