Thread: Antennae Help
Old 8-Sep-2011, 7:53 PM   #2
A small Antennas Direct DB-2 facing about 65° would receive all the channels in the green section of your report. After disconnecting the cable drop from the grounding block you can connect your antenna to that point, feeding all the outlets in the house. You're right, you have plenty of signal so resist any temptation to use any type of amplifier.
