Well you would need a rotor if you want to get all the stations on the plot. Nice thing is a bunch are in the same direction so you can point it in one direction for each group like 184 degrees for 22,26,25,42,44, and 45. Then 294 degrees for 32,19,46,16,40. and there are other stations in groups in the same directions. that is if you want to mount a antenna and rotor outside.
you might be able to get away with a good omni antenna but I dot know any thing about those antennas.
Someone will get in here that knows this stuff and will tell you if my advice is ok or not and maybe have a better sugestion.
Roger
