Your plan to mount outdoors and at 35' puts you at an advantage. Lower or attic mounting would give you less signal to start with.
The weak signals to the south of you call for a large antenna such as the Winegard HD7698P. I would also suggest replacing the preamplifier with an Antennas Direct CPA-19.
If there is any possibility that the existing coax has moisture in it, replace it.
