If you use the HD7698 or HBU55 you'd get everything from the top on down to WTAE TV in the red. Everything below that is hit or miss. I used the Pending Digital signals to get an idea of what you might expect to see in the near future for channels.
Will you be using a rotor? If so, either of the antennas above will do just fine.
