Thread: Grounding Block
Old 7-Apr-2010, 3:53 PM   #1
Dick
Grounding Block
I've read that the electrical code calls for mounting the lead-in grounding block as close to the point where the cable enters the house as possible, but was wondering if there is any advantage or dis-advantage to mounting on the antenna mast connected to the mast grounding wire? Can a grounding block be mounted at both locations: also, advantages/dis-advantages? Thanks
Dick is offline   Reply With Quote
