Thread: Antenna Help!
Old 7-Sep-2011, 6:31 AM   #1
Ziffster
Question Antenna Help!
Hi,
We are thinking about getting a Clearstream C4 to replace an small older VHF/UHF antenna (about 100" in size) with no booster. We would like to increase the number of stations we get.
We always get: 14.1, 18.1, 19.1, 20.1, 48.1
We sometimes get: 31.1
We never get: 6.1, 13.1, 51.1
The analysis is: http://www.tvfool.com/?option=com_wr...838762e32cbf77
The mapping hasn't been updated so you need to look at 'Digital Only - Current + Pending' to see the correct results.
Should changing to the C4 help? If not, does anyone make an antenna which will help?
We would like to avoid the need for a router - but as the TV has dual tuners we could go with two antenna pointed in different directions if they can be mounted on one mast. Is their a pair that you would suggest installing and how closely together can they be mounted on the shaft?
Your help would be greatly appreciated!
Ziffster is offline   Reply With Quote
