Based on the signal here near Beauharnois they are either at the East End location or running lower than normal power. The Analog signal on 17 was very much stronger. I suspect it will take a few weeks before everything is organized with the various stations. There are just so many RF engineers around and everybody had to cut over at the same time... a logistical nightmare ;-) You could always send an e-mail inquiry to the station...
BTW, do you know what has happened with CFJP (35). I could never receive them on 42 because of the location and low power but they should be solid here on 35 with their published 825KW ERP
