Tv Antennas and Reception
If the construction of the building that the Tv is in is , wood frame with wood or vinyl siding then reception will be ok. However if the construction is metal siding , metal roof , metal foil backed insulation , concrete , bricks from ground to roof , solar panels , then the reception will be reduced or blocked. Also if the antenna is below ground , like in a basement , the reception will be reduced or blocked. Also trees with dense foliage can reduce or block reception.
