Old 3-Sep-2011, 11:05 PM   #52
The shield portion of the coax should be connected to ground, for safety and some say, reduction of interference (the latter could be the subject of a rather pointless discussion, because the protection from static discharge damage to your tuner seems enough reason to ground the coax shield, IMO).
A ground block is used to make that connection, it should connect to your electrical service ground through a fairly short #10 copper wire.
