Originally Posted by DennisC
... The ground rod is 3/8" X 4' and is copper plated - hopefully that is acceptable.
Can the insulated copper ground wire be placed next to the coax cable and share the same exterior wall fasteners down the side of the house?
Again, Thank You
Dennis
Many people overlook grounding... so you're already doing better than most. Ideally, the new ground rod will be connected to the existing ground system that serves your electrical system.
Regarding wire next to coax, as JC says, yes that's fine.
