Tv Antennas and Reception
Yes the shopping list is correct. Yes RG-6 quad shield can be used , it is stronger and more durable. Always look inside of coax connector on the ends of the coax , see if the foil shied and shield wires are pushed in toward the center conductor that carries the signal , if so , push the foil shield and shield wires away from the center conductor.
