Originally Posted by John Candle
Your location is a lightning and storm prone , I recommend a coax grounding block connected to electric service ground or if electric service ground is not doable the a cold water pipe ground or drive a 6 foot ground rod in the ground. Here is a picture of a coax ground block , http://www.amazon.com/Channel-Master.../dp/B000BPEZKK
I agree, grounding the tower, and coax shield is well worth the cost. Connecting to the existing electrical service ground is the the best choice, worth extra effort if needed.
http://forum.tvfool.com/showthread.php?t=901
Reason: I was sounding too grim.
