Tv Antennas and Reception
GUM is correct on all points. Antenna gain is more important then amplifier gain. I recommend a bigger antenna , Winegard HD7697P antenna aimed at about 195 degree magnetic compass. No amplifier is needed. Also get the antenna higher , about 25 feet if you can.
