Once you establish where your antenna(s) will be located, you need to calculate total signal loss from that point to each tv location to see if the existing system will work as is.
Splitters feeding splitters is not good. One distribution point is best and hopefully you have RG6 coax throughout rather than the old RG59 cable.
