Old 1-Sep-2011, 6:42 AM   #2
John Candle
Tv Antennas and Reception
Yes it is what you have said about reception conditions , the signals can be very strong at times. The ducting process through the sky is interesting and fun for reception. You could put up another CM4228HD with a Antennas Direct CPA-19 preamp , on a CM9521A rotor and rotate around to different points on the compass , you would suprized , some like , WXCB-CD 45 and WMNO-CA 28 would be received all the time and the others around the compass would be received most of the time or some of the time. A separate coax would go to the location of one Tv and a A/B antenna switch , model AB27RS or radio shack 15-1968 would switch between the antenna you have now and one on the rotor. There are Tv and Radio DX websites on the internet , it's a great hobby. There is also ground wave reception , Tv and Radio signals can go along about about a foot or so above the ground.
