Old 1-Sep-2011, 3:47 AM   #19
Billiam
You indicate that you would really like to watch Fox. The Fox affiliate is carried on Ch. 18's subchannel. That being the case, the Channel Master 3023 has superior reception on UHF low channels while the 91XG has better gain on the higher UHF channels. If that indeed is your most important catch and you are willing to sacrifice a bit of gain on the higher Channels over 30 or so, then that is the best antenna for this situation that is presently still available unless you have the big bucks to go and get a commercial antenna. :-)
