Old 1-Sep-2011, 1:09 AM   #9
Originally Posted by bveedub View Post
Thank you, I will buy a winegard ap-4700. You also mentioned a NF of less than 3dB. What is it? Thanks for your help, I will let you know how it turns out. Jeff
NF = Noise Figure. It's a measure of the amount of noise the amplifier will add to the signal as it passes through the amplifier. It would be nice if the amplifier did not add any noise which would be expressed as a NF of 0 dB. The reality is that all amplifiers will add some noise. The lower the NF, the better. I would not be at all surprised to find the NF of the Radio Shack amp to be around 6 dB.
Once noise has been mixed with a signal, an amplifier can not remove it.
