Old 31-Aug-2011, 9:41 PM   #8
Try pointing it toward the north were most of the stations are located relative to you. If at all possible, give the antenna as clear a view of the transmitter towers. Behind the TV is quite often a poor location for an antenna, particularly if the TV sits between the antenna and the transmitting towers.
