Old 31-Aug-2011, 3:55 PM   #2
What are you using for an amplifier? Some amps are frequency specific, others require that a proper internal configuration be made.
Could you post a TVFool plot for your exact address? See this post for instructions.
What direction is the antenna (narrow end) pointing?
Estimated cable length from the antenna to the TV set (furthest, if more than one). Any splitters? If so, identify them and describe your cabling layout.
