Can you budget some money to install a small tower if need be? After looking at your report it is evident that you will only get a few analog signals and perhaps one digital signal at the current height that you give. If you have the money for a small tower, rerun your report with some different heights to see if there is much of an improvement in your Noise Margin (NM) on the channels in red on your report. Figure anything over Zero to plus One right now will be gettable if the strength improves. The trees on your property are going to be a problem just as they are on my own. I've found in my current situation because of the trees I have a tough time getting a reliable picture on a signal with a NM less than 3.0 on the plus side.
