Originally Posted by cmihai
Sorry for not being explicit enough. I have Fox in the list from previous scan, however current level is 0 while peak level is 98. Status reads Unlock, SNR (dB) is 0 and AGC (%) is 62. Since the channel is in the list, do I need a rescan? Thanks again!
It sounds like the answer is 'no, you don't need to rescan'. With an indicated SNR (Signal to Noise Ratio) of 0 dB, you have significant evidence of low signal level, noise, interference, multi-path or some combination of those.
But sometimes, after trying everything else...
