Old 30-Aug-2011, 8:20 PM   #21
cmihai
Originally Posted by Billiam View Post
cmihai. See if a friend or neighbor or two will bring over a HDTV for you to set up to compare. If you still don't get this channel on at least two other televisions (preferably a different brand from your existing unit) then we could probably rule out the problem is with your tv tuner. Start here first. This is a cheap way to troubleshoot the problem.
This is a great idea to rule out the TV tuner Billiam, although it might be difficult to implement - I'll see what I can do.
I really want to try GroundUrMast's suggestion this evening, to remove the splitter, as it is incredibly easy to implement.
Would get back to you when I'll have new information, do not want to start another fire. Thanks again!
cmihai is offline   Reply With Quote
