Old 30-Aug-2011, 8:04 PM   #20
Billiam
cmihai. See if a friend or neighbor or two will bring over a HDTV for you to set up to compare. If you still don't get this channel on at least two other televisions (preferably a different brand from your existing unit) then we could probably rule out the problem is with your tv tuner. Start here first. This is a cheap way to troubleshoot the problem.
