Old 30-Aug-2011, 3:27 AM   #7
John Candle
Tv Antennas and Reception
As an experiment you can aim the antenna at 228 degree magnetic compass and try for WVBT 29 Fox and WTVZ-DT 33 MyNetwork , however the stations are very weak and reception is a 'experiment'. You can add a Antennas Direct CPA-19 preamp to the antenna , to reach out for those stations , like I say it is a experiment. You can also try for the the analog stations at 250 degree magnetic compass and see if any of them are transmitting. You can also find out what programing is on Tv stations by typing the stations call letters like this - wtvz tv - (with out the dashes) in the google search box. Here are some converter boxes that convert analog to digital and some will receive digital and output digital at low definition digital and high definition digital. http://forum.tvfool.com/showthread.php?t=380. Some have built in recorders.
