Old 30-Aug-2011, 2:09 AM   #2
Reception of an ABC affiliate is the determining factor here. You will need a roof mounted antenna with as much gain on real channel 13 as can be had.
The Winegard HD7698P fits that criteria. Pair it with an Antennas Direct CPA-19 preamplifier, a good tripod and mast section and you should see all of the networks you listed... +.
(Sorry if this scrapes the ceiling of your budget.)
