Old 29-Aug-2011, 10:28 PM   #47
You won't harm the tuner in your TV or STB.
Often Radio Shack, like many retailers, offered little in the way of technically accurate specifications.When selecting an amplifier, you need to know gain, bandwidth, noise figure and maximum signal capacity. The last two specs are often omitted in advertising material and may not be published in any other form.
The bottom line is, try it... if signal quality gets worse but you truly need an amplifier, post the most current TVFR for your location. We need to see what the rather dynamic signal conditions are like before we could recommend a preamp or DA.
(I can still see CBUT, real channel 2 here in Seattle so expect the powerful CH-2 signal to cause trouble with your amp. It can't tell the difference between analog and digital.)
