Tv Antennas and Reception
I still recommend the 2 antenna solution. With the 2 antennas installed and the coax wiring installed. A hand held remote controled A/B antenna switch , model ab27rs or a radio shack 15-1968 is used to switch from one antenna to the other. No waiting for the antenna to rotate around. And with the A/B antenna switch set up , a second or third Tv can be added and each Tv will have a A/B antenna switch to watch what ever they like. You can do the antenna and rotor now , and do the second antenna thing later. So now you say what do I do with the rotor ?? I won't need it when a second antenna is installed?? My answer , leave it in place or sell it in the garage sale.
