Old 29-Aug-2011, 6:42 PM   #11
cmihai
Two of the splitter outputs are connected (to one TV each), one has a coax F terminator and the last output is currently wide open (I realize this is not the ideal situation). Later on I'd need to connect it to the third TV in the basement.
The highest (first in line) pre-amp gain is at about 28 db on UHF. The second (in line) comes at about 19 db UHF. I red that the pre-amp is supposed to compensate for cable loss and should not provide much more than the actual cable loss, otherwise it might burn out the TV tuner (if I'm not mistaken). As mentioned in the first thread, my cable loss is at about 17 db that is why I decided to go with a 19 db pre-amp gain. I was afraid that 28 db would be too much of a good thing
cmihai is offline   Reply With Quote
