Many people have no idea and I mean No Idea at all what direction is what direction . Antenna aiming is a process. The direction in degrees is given , this get's the antenna pointed in the direction the antenna will need to be pointed at and then the antenna is turned to the left and right to get the best reception of the channels the person will like to receive. In your case I gave a direction that is in between the two groups of stations and then you turn the antenna for best reception. As time goes along I change my wording so that more people can and will understand. You must understand that we are dealing with some people here that do not even understand the , north , south , east and west. Think about it , if you were using words only and you were explain how to aim a Tv antenna , what words would you use??
