Old 29-Aug-2011, 6:03 PM   #3
No static at all
No static at all's Avatar
I agree with GUM that anything less than an outdoor antenna will likely provide dissapointing results. My minimum recommendation would be the Winegard 7694 aimed at Richmond with a Channel Master 7777 pre-amp. The antenna should provide you with all the major networks & maybe the CW from Ashland.
The recommended antenna is very small & should be inconspicuous to anyone that may be offended by it's presence. Those HOA people need to get a life.
