To simplify one TV setup is fine for now.
Instead of using two antennas could one antenna with a rotor be setup? Then with a box that when I change the channel it would rotate the antenna by itself? Or even something I could rotate by myself?
I'm guessing no omni directional antenna exists that could pull some NE and S?
Can two antennas be spliced together to pull it into one line without an A/B switch? Or is that impossible?
