For your reception situation , I recommend a Winegard HD7082P antenna with Antennas Direct CPA-19 preamp mounted on a Channel Master CM9521A rotor. You will receive the stations in the , green , yellow and red. A antenna on a rotor works Ok for one Tv hook up . However does not work well for more then one Tv because conflict will happen over the direction the Tv antenna is pointed.
