Old 27-Dec-2009, 9:56 PM   #1
jedidieah
Only get 1 channel
http://www.tvfool.com/?option=com_wr...4105ed9c2e09d6
I bought an outdoor antenna, from the local wal-mart, it's an RCA, says it has 40 mile range, I installed it next to the Sattelite, it is 7 feet off the ground level, and the coax from the antenna is wired into the sattelite splitter box and runs through the sattelite cable runs to each receiver where I've used a splitter to separate the sat and ant signals again. I'm sorry I don't have more info on the sattelite splitter, it has two lnb inputs and and an ant input and four receiver outputs, the splitters at the receivers are 2200 diplexor, I get NBC with a 100% signal, but none of the other channels receive any signal, I have used the signal meter on my digital LCDTV to check them.
Any ideas on what's keeping me from getting the four pbs 4-1 through 4-4 channels, CBS 11-1, ABC 11-2, and a local weather channel, 11-3 and fox, 38-1 from coming in?
Thanks
jedidieah is offline   Reply With Quote
