Old 28-Aug-2011, 4:05 PM   #2
Billiam
No amp needed at your location. Virtually every station is in the Green and will give you a strong signal. Usually the higher you mount your antenna the better your reception will be. But this is not true in every case especially with digital signals when in some cases you can find a "sweet spot" at a lower point on the property.
You will need a splitter if you want to add a second tuner or TV at some point. They are pretty cheap and only run a few dollars.
Question. Do you want digital signals only or do you plan to watch analog as well?
