Old 27-Aug-2011, 10:25 PM   #6
Don't count rabbit ears out. Yes it is less likely that rabbit ears will receive these elusive signals , however sometimes the long distance signal can be concentrated and Wham'o even the rabbit ears will receive a clear strong signal for even like hours at a time. And Digital Tv Transmissions are not as fragile as you think. In some ways Digital Tv is stronger and more durable then analog Tv. Digital Tv has built in digital picture and sound correction and produces clear pictures and sound. Analog Tv has lousy pictures and plain FM sound. It also takes less power to transmit digital over the same distance then analog.
