The weak signal from WBAL and WBFF call for a roof mounted antenna such as a Winegard HD7696P. I expect that you will need an amplifier to overcome splitter and cable loss. Consider the Antennas Direct CPA-19 or the Winegard HDP-269. Aimed at 163°, that antenna and others like it (directional & moderate to high gain) will not reliably receive the group of stations NE of you. (But you may get lucky.)
Keep the current indoor antenna (possibly in the attic). Keep the two antenna systems separate, up to an A/B switch at each TV to select the desired antenna.
