Old 2-Apr-2010, 7:23 PM   #18
Lightbulb Tv
Your local newspaper should have a listing of the local analog translator channels. The name of the translator owner is Valley Tv Cooperative Incorporated , Moorefield P.O. Box 151 , no phone number. All of the channels that you can receive at your location are UHF channels both to the south east and north east. An antenna amplifier may not help much at your location. The signals are strong , its a matter of finding a hot spot location for the antenna. This is known as probing with the antenna , to find the best signal. You can look at pictures of Tv antennas on the internet and decide what your antenna is. You can put up 2 tv antennas one pointed N/E and one pointed S/E. At Radio Shack you can get a Remote Control A/B switch to switch between the 2 antennas. At Home Depot , 'Top Rail Fence Pipe' used with chain link fence , can used as antenna mast. Here is a little known Tv channel guide that has a lot of information http://www.titantv.com/
