Old 25-Aug-2011, 4:23 AM   #10
John Candle
Tv Antennas and Reception
WQED is WQED and WNEO is WNEO. One is not a repeater for the other. http://en.wikipedia.org/wiki/WQED_(TV) , http://en.wikipedia.org/wiki/Western...e_Public_Media. It is a good idea to go a size bigger with Tv antenna when dealing with weak signals , the single digit NM (dB) numbers in red of the radar report. The bigger antenna helps make up for negative reception variables like , trees , buildings , weather (rain snow) and etc. that can degrade or block tv transmission and reception. I helped some people that lived on the other side of a land fill , from the tv transmitters , the land fill/mountain was very high , they did not get much in the way of Tv reception. . It looks like the HD7696P has been discontinued , it is now recommend to use the HD7697P antenna. The HD7697P antenna will work in place of the HD7698P. The CM4228HD will likely not receive any thing below WNEO , but you can give it a try. . You will be receiving the 2 groups of Tv stations to the west that have channel 48 in the middle.
