Old 25-Aug-2011, 3:11 AM   #9
richnerd
You know I'm laughing here because I too feel an attraction as I learn more.
Ok, so I now know that I will be getting/needing a pre-amp; thanks for the insight. John-no I'm not living off the grid or anything but It's something I'd like to work to at some point.
Also, I do plan to mount outside to start off with due to both of you common sense suggestions.
One thing I'd like to ask is John mentioned the getting weak stations like WNEO-DT 45 PBS...how does the repeat stations work? If I am able to get WQED-PBS is WNEO-DT PBS a duplicate station and just repeat?
Also, if I did go with a HD7696P or a Channel Master CM4228 HD what would I likely lose i.e. channels, quality, etc.?
Is it safe to assume that no matter what antenna is chosen it is agreed to point at 271 degrees?
richnerd is offline   Reply With Quote
