Old 24-Aug-2011, 11:24 PM   #7
No Static at all and Dave Loudin are saying , give up , don't even try. I say give it a try. I think my recommendation will receive the channels down to WXFR. Here are the stations I think will be received , WVPT PBS , W41DT has digital channels , NBC , Weather and CW+ , WSET has digital channels ABC and RTV , WDBJ has digital channels CBS and My Network , WXRF has digital channels FOX and The CW. . I recommend 2 Channel Master CM4228HD antennas , one aimed at 14 degree magnetic compass and the other aimed at 223 degree magnetic compass. Two Antennas Direct CPA-19 preamps will be connected , one is connected to one antenna and the other is connected to the other antenna. The coaxes from the antennas/preamps/power supplies will be kept separate. A 2 way splitter will be put on each coax on the ( Tv side ) of the power supplies. The outputs of the splitters will have coaxes that go to Remote control A/B antenna switches , Model number AB27RS or radio shack 15-1968 , at the 2 Tv locations. And the outputs of the A/B switches go to the Tv's.
